Hi. I've noticed that new feature showing battery level for connected bluetooth accessories is wrong. I have SBH70 and I use your Stereo Bluetooth Headset SBH70 app from Play Store (https://play.google.com/store/apps/details?id=com.sonymobile.hostapp.sbh70) which shows battery level in hours (play time). I works well, never failed.
After Pie update there's new one feature. You can see battery level in % under bluetooth icon. But it shows wrong % level.
As you can see from screenshots:
So new Pie feature is clearly wrong because my SBH70 was about to "die" but according to system there was enough power to play for another 5 hours..
So hurry up, fix it, fix it...
I can't charge my bracelet anymore. Today I took it apart and found the battery bulge. By the way, I found the battery inside a Bluetooth headset and changed it. It is still charging…
