my xz2 has sound problems
elsharawy
Sometimes Recording voice note on WhatsApp is recorded with no sound just 2 sec from my talks then nothing. there is distortion in sound of notification and games any help or solution
1 REPLY 1
profile.country.NL.title
Strampke
You can do some testing.
See if it's just WhatsApp or other apps as well.
Open the support app, bottom right side, Xperia tests and let the device test itself.
You might consider testing with a voice recording app as well.
Report your results and ask of you have further questions.
