Any idea of why this is happening? 8mins screen on time but my battery went from 100% to 79%
new phone? give it a little time to set it down. Give a reboot also. But android system is eating to mucht juice in my opinion. need to check it out..
you can make a test with safe mode...
same behavior tonight battery dopped from 89% to 49%. Before, battery usage overnight was near to zero!!!!
It seems to have been fixed, I uninstalled Twilight and Lifelog and battery usage was back to normal. Just that "Phone Idle" is always number 1 on my list but that is a known Sony thing
@Kycpokemon "Phone idle" simply shows on the top of the list if the phone has been lying around not being used too much. if you're a heavy phone user, the top spot on the list will be taken by the screen.
