Sometimes when i open camera, it says 'error,unknown error' and flashlight is unavailable.
Then i find it happens when the phone is over heating. But I didn't use camera at those time.
To get it back to normal, I have to restart the phone after it cools down.
So is camera and flashlight affected by the temperature even if i don't use them?
Finanlly I find an easy solution to solve this. All we need to do is just power off and put it in the refrigerator. Take it out after a couple of hours and boot the phone, it works. If you put it in the freezer, half an hour would be enough.
But it's not a once-for-all solution. Problem still occurs when phone gets over headted next time. I do this about 4-6 times per month.
The main concern is I have no idea if it will do any harm to my phone.
I have the same problem, when I open the camera it tells me an unknown error, the Led light does not work ....
Any solution ?
Tengo el mismo problema, cuando abro la cámara me dice error desconocido, no funciona la luz Led ....
Alguna solución ?
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
The phone can't overheat, if it gets too hot, it will stop some apps/functions to help cool down the device and prevent any physical damage, if it gets too hot, it will shut down
Same story. Any ideas how to solve ?
Does this only happen when your device gets too hot? if so, then there's nothing you can do about it
It's been more than one week since last time when my camera and flashlight become unavailble, I have no idea when it will be back to normal.
It happens even when phone cold as piece of ice. After hard reset problem not solved. From now on camera is not working at all.
I suggest you run a system repair with the Xperia PC Companion to rule out any software issue.
If this doesn't help it's time to contact your local support to get a repair.
Done. But still unknown error with camera.
Just to check:
The battery was charged, you did the software repair, no errors and after that your camera still gives this 'unknown error'.
Question: did you restore the backup?
Fact of the matter is that sometimes 3rd party apps can cause trouble.
If you did restore the backup then I suggest to redo the software repair with Xperia Companion only this time don't restore the backup.
Just install the most needed apps and just mainstream apps from which you can expect that those behave nice.
If you already did so and still have these problems then your device is due for repair.
In that case open the Support app on your device and let that guide you to official Sony repair in your country.
