After updating the device to Android MM , i found that small apps and navigation buttons are overlaped which makes small apps to launch very difficult...and if you remove any shortcut from the small apps bar...its imposible to add it back..or any other small app to it. You have to rotate the screen so that navigation buttons doesnt appear on that...and than add icon to it...
check the snapshot.
do anyone having the same prob on xperia z3+
This is covered here:
/t5/Xperia-Z5-Z5-Compact-Z5-Premium/Android-6-0-small-apps-launch-bar-issue/td-p/1101361/page/5
No need for another thread.
