Shown in the picture... The launch bar "fell". But when I tried to launch a small app I still have to touch the position above navigation bar...
I think you guys are covering the issue I'm having. I'll attach a pic if it's not hard to do. FYI I do have smart launcher, but the issue exists whether or not I use it. I'm on the z4 tablet, freshly upgraded to 6.0.
Do you see how the keyboad menu (start menu) overlaps the small apps? The three on-screen buttons (back, home, recent) are also on top of the small apps. Imagine the inconvenience! XD
Edit: Oh, you know what? Since I'm amazingly observant, I've now noticed that the start menu actually contains all of your small apps. You can cycle through and access each one. The keyboard also physically has those on-screen buttons. That said, I'm still annoyed about the overlap problem, but now it's just not as inconvenient as it was. I mean, what if I'm not using the keyboard, right?
I have a xperia z5 compact, small bar does not work after android 6.0 update...
Hello! Booting in safe mode and back, solves the problem, but, when booting back from safe mode, all of the non sony widjets on homes screens are disappear!!! Realy frustrating!!
Yes, but it is a temporary solution. After some time the problem is there again.
@leventech wrote:I have a xperia z5 compact, small bar does not work after android 6.0 update...
Small update: I find the solution for my z5 compact (at least for myself)
Setup > Accessibility > Services > [Application RF] to OFF, bingo small apps working...
@Leventech
That is exactly the root of the problem!!!
