Assortment of problems
Mascibran83
Good evening, members of this forum! My phone began to turn itself off and not restarted if I did not would link the corresponding button. Later, the phone began issuing the voice of a woman speaking English (I could not understand what she was talking), and from this event, I could not move the device. The screen was locked and that "woman" can not stop talking. I get calls, but I can not meet them. Crazy, no?
1 ACCEPTED SOLUTION
Phy
Legend
Legend
It's not crazy, you are crazy.
unlock the screen, then drag down the notification bar try one finger if it doesn't work then try 2 fingers, access the settings then look for accessibility, and disable talk back.
9 REPLIES 9
Phy
Legend
Legend
Phy
Legend
Legend
You could also reboot on safe mode, just in case the issue its from a third party app.
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
Jake-SonyXperia
Champion
Hi Mascibran83,
This is Talkback mode, this mode is used for the Blind.
Phy is correct with the procedure, however there are a few more things you should know when trying to access the phone.
To unlock, use two fingers spread apart and swipe upwards or Downwards, once unlocked you will need to select functions with three taps. The first tap will make the phone state the name of the function, after she does this simply double tap the app and it will open.
Follow Phy's instructions using the above method.
I hope this helps.
JoelRaj
Funny... Just try to disable the talk back. You will have to touch twice when that sweet women talks back what you touch lol... To do the corresponding task you want. Then go over settings like mentioned by the other pals and disable the mode
dandy63
Leader
Now....if only we could do this to real women to stop them talking all the time  Smiling_Face_with_open_mouth_&_closed_Eyes
Phy
Legend
Legend
wow Thinking_Face
Curnow1
Contributor
Dandy xD
dandy63
Leader
Hi @Phy & @Curnow1 ..........my feeble attempt at a bit of light hearted humour on the Forum, my appologies if it offended you, if so you may ask a Mod to take it down Flushed_Face
Curnow1
Contributor
Dandy nah i think its ok and funny xD
