Deel jouw ervaring!
Please help me to solve the message attached below. Z5 Premium. Cannot access audio settings. Receive the same in safe mode. Thanks.
Opgelost! Ga naar oplossing.
I was able to resolve the problem by luck. I had recently installed a bass booster app by Desaxed Studios. I uninstalled this app and the problem was fixed.
Question - does anyone know of a good bass booster app that does not conflict?
Thanks for your help.
I have a Z5 Premium. Need help to correct this problem. When I click on Sound and Notification > audio settings, I get the following message;
This function is not available because some other sound effect application is active in higher priority. To enable the function, go to Settings > Sound > Music effects and enable Audio settings.
Advise best way to correct this so audio settings are functional again.
Thank you.
How to boot on safe mode
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
How to boot on safe mode on Lolipop
1. press and hold the power key
2. once you get the pop up menu
3. press and hold "power off"
4. Boot on safe mode should become available
Can you explain you reply below more clearly? Thanks.
Do you have OK google enabled everywhere?
Also, same situation in safe mode.
Thanks again.
Settings > language & input > google voice typing > OK Google detection > from any screen > turn it off
Two points Uliwooly;
Google settings are OFF.
Same problem in safe mode.
Do you have other solutions?? Need your help, thanks.
