Battery Charging. And Drain fast
131B
Hello,
first, (sorry for my bad english Face_with_stuck-out_Tongue )
i hav'e sony xperia Z c6603
everything is ok
but the battery is charging fast And problem is draining faster ~.~
There Any solution to make phone take his time when charging?
thinking that maybe will fix .fast draining problem
tried Repair with (PC Companion) But Nothing changed
Any Solution?
And thanks
1 ACCEPTED SOLUTION
Uliwooly
@131B
In that case, I'm nost sure, you will have to contact the store where you bought the phone.
3 REPLIES 3
Uliwooly
@131B
Probably the battery doesn't hold the charge anymore since the phone its more than 2 years old. Contact your Local support to get it replaced.
131B
Oh Thanks.
But what they can do for me?
Change battery or somthing..?
bcz i don't think here in morocco have :p,,
Uliwooly
@131B
