Hi Abdeljalil, welcome to the community!
What is using up the most battery under Settings > Power management > Battery usage?
Some things you can try to maximise the battery life of your device:
If you try these steps and they don't really help or you feel that the battery life is definitely not normal, I would then advise running a software repair on the unit;
Back up your device first:
1. Go to Support to install PC Companion on a Windows
computer.
2. When installed, start PC Companion on the computer.
3. Connect your phone to the computer using a USB cable.
4. Click Start under Backup & Restore.
5. Follow the on-screen instructions.
(Exactly what contents will be backed up may differ
depending on phone model.
You can view detailed information about this as you follow
the steps in the Backup & Restore wizard).
Running the software repair on PC Companion:
1. Install and open PC Companion then select Support Zone.
2. Phone Software Update.
3. Start.
4. Repair Phone
5. Continue
6. Accept data removal
7. Next
8. Wait for prepare
9. Select Phone
10. Follow the connection steps
Keep us updated!
All pissed of Lollipop sufferers downgrade to good old Kitkat!!
Its the best solution.
5.1.1 drains a little faster than 5.0.2. And yes, i can make a fullwipe a week, but no changes.
Welcom!
for sure I turn off all connectivity stuffs when they are not in use. I tried a lot of battery saving modes but nothing really help me.
I heared that the problem started with lollipop update. I will install windows later and try PCC then I will see
I see Abdeljalil, yes try re-installing Lollipop with PCC it is likely to smoothen the OS out for you. Keep us updated.
