Battery Not performing as Good as Expected.
kaustubhtrivedi
My Z3 is now just 3 months old.It is supposed to have a good battery life..but it is just fine for my phone.. I am posting my battery usage.How much does it last for other people while using wifi and music.??
I have put the brightness very low and it is adaptive to lighting conditions enabled..
BATTERY Usage
9 hours 17 m on battery
Current battery status 69%(12:45 pm) it was charged at 91% in the morning (9:00am)
Screen 43%
Cell standby 10%
Mediaserver 8%
Android system 7%
Phoneidle 6%
Chrome 6%
Android os 5%
Walkman 4%
Wifi 3%
How can i improve my battery life.Is there some software problem.Please help.thanks.
1 ACCEPTED SOLUTION
stockyvillage
Contributor
Enable stamina mode or if you don't won't to do that,you can now use greenify on unrooted phones,but you have to manually enable it and then add the programs you want to hibernate. You can then add a lock and hibernate shortcut to home screen.I use the program myself and have done since last October on my Z3 with no problems
9 REPLIES 9
Uliwooly
That's normal battery life.
kaustubhtrivedi
@uliwooly but the battery lasts for only one day at maximum..
rajanv
You can enable Stamina mode to get more life.
stockyvillage
Contributor
Uliwooly
@kaustubhtrivedi
Follow   @dandy63 @rajanv @stockyvillage   's advice
kaustubhtrivedi
Okay.. thanks a ton @uliwooly
kaustubhtrivedi
And others too..Thanks guys.
Uliwooly
Anytime
