can't receive incoming calls
Noble1
If I am on a call, I don't receive any notifications that someone is trying to call me. The only way I know that someone was trying to call is through a third party app or they text me and tell me. The third party app is for voice mail.
Tags (1)
1 ACCEPTED SOLUTION
Thommo
Settings - Call settings - Additional settings then tick the box at the bootom
4 REPLIES 4
Thommo
Noble1
Thanks, that solved it!!
1bit
It's called Call Waiting and you can also use GSM codes:
*#43# - to check status of Call Waiting
*43# - to enable Call Waiting
#43# - to disable Call  Waiting
MiniJeezy
I don't receive incoming calls at all on my phone (sony xperia z3 dual) so I called the phone company and they said the problem with the phone not the service. Could you please tell me how to fix this issue?
