So I've just run a diagnostic check to make sure all is well & it's failing the Light Sensor test.
The test shows an image & asks if it fades when I cover the upper part of the device, however the image fades as soon as I run the test (without anything covering the upper part of the device)
So a few questions, if I may:
Thanks in anticipation?
Paul
Thank You Very Much!
I followed your instructions to reboot in Safe Mode then ran the diagnostic check & the Light Sensor passed
I then restarted as normal & ran the diagnostic check again & it passed again!
Paul
