Handsfree sound not good
xperiaz14
I am satisfied by the speaker quality of Z2 that it is far much better then xperia Z1 but not satisfied by the quality of Handsfree sound. Currently I am using MH750 but the Handsfree sound is not loud as Xperia Z1. I also tried MH-EX300 on it which I was using on Xperia Z1 and fully  satisfied by the performance.
1 ACCEPTED SOLUTION
profile.country.US.title
Qatrium
@xperiaz14
Try refreshing your Smart Connect app:
- Go to Settings -> Apps -> Smart Connect -> Force stop, Unistall updates, Clear data and restart your phone.
- Go to your Play Store and update Smart Connect again.
7 REPLIES 7
Qatrium
@xperiaz14
Can you elaborate what's the issue with your headphones? Is it the volume or you hear static sounds or distortion?
xperiaz14
the sound quality is not good not much clear as well as loud as compare to xperia z1.
Qatrium
@xperiaz14
Do you use the same audio settings as Z1? Like ClearAudio+ or equalizer?
xperiaz14
I have tried both the conditions i.e. clear audio+ and in off condition
Qatrium
@xperiaz14
xperiaz14
Thanks. I will tell you the result tomorrow.
xperiaz14
I am very thankful to you Questor. problem solved.
