help me
ROZWIĄZANE
mohamed_ebrahee
Początkujący
help me
when i install a software fo sony z1 by sony pc companion it stopped and the programme can't continue then the programme can't connected with my phone how i install the software
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
Make sure the device is not connected to computer or laptop and turned off (sometimes you have to press power button and volume up until the device vibrates 3 times or on some devices you have to press the small button near the SIM tray or on the back of the device).
Open PC companion->support zone->phone/tablet software update->repair my phone/tablet blue highlighted.Follow the steps given,do not connect your phone until prompted to press volume down while plugging USB cable. If PC companion does not start the repair process, you might need to run it in compatibility mode with Windows 7 (in some cases XP).
alexdon
Wyświetl rozwiązanie w oryginalnym poście
5 ODPOW. 5
_alexdon_
alexdon
mohamed_ebrahee
Początkujący
thank you very very very much :smileyhappy::smileyheart:
_alexdon_
So it works?
alexdon
mohamed_ebrahee
Początkujący
yes
than you
_alexdon_
Great.
alexdon
