noise cancellation earbuds
walidelass1
after that my Xperia touched water in my shower, it won't recognise the noise cancellation earbuds and they stopped working
1 ACCEPTED SOLUTION
dandy63
Leader
Also try....... Settings - Apps - Smart Connect - Press Clear Data and restart phone  :smileysmileywink:
4 REPLIES 4
dandy63
Leader
Hi, make sure (if you have not already done so) that the headphone socket on the phone is perfectly dry & free from any obstructions like dirt/fluff etc.......is everything else working fine ie your screen/calls/internet/camera etc :smileysmileywink:
dandy63
Leader
walidelass1
Thank u so much brooo u r the best
dandy63
Leader
Hi, my pleasure....glad it's sorted :smileysmileythumbsup:
