PDF problem on my Experia Z3
Bigbrossi
Hi Everybody
I hope someone can be able to help me out here.
One day while I was about to open a pdf file, by accident I told Z3 always to open pdf files with dropbox.
How do I set my Z3 back to use the OfficeSuite (which comes pre-installed on Z3) always to open pdf files????
Regards
Bigbrossi
1 ACCEPTED SOLUTION
profile.country.RO.title
_alexdon_
Go to dropbox under settings-apps-all and clear defaults. Then open a pdf file and select a different app.
alexdon
4 REPLIES 4
_alexdon_
alexdon
Christofer
Champion
Hi @Bigbrossi,
Clearing defaults, as alexdon suggested, will make your phone forget all actions previously associated with the app in question so if you clear defaults for Dropbox you will once again be asked which app to open .pdf files with the next time you open one. Slightly_smiling_Face
Bigbrossi
Thanks you guys...it worked 🙂
_alexdon_
Anytime.
alexdon
