Power Consumption in Z3
YaeNoi
I use Z3 for 2-3 days now.But last charge I found standby time drop from 2 days to 1 day. Anyone have any idea, help me please.
1 ACCEPTED SOLUTION
Thommo
Are you looking at the estimated battery time as this is all it is "Estimated" and is based on your use over a few days prior, So if you had heavy use prior then the estimated time will drop based on your use and if you had light use then that time will increase
1 REPLY 1
Thommo
