Problem: Notification Sounds and Ringtones
Global
Hi everyone. I have opened a topic about the sound distortion in the beginning of any sound on device. Alexdon[http://talk.sonymobile.com/t5/user/viewprofilepage/user-id/7878] helped me very much. But i have noticed something different.
I did a factory reset and a clean install the latest update. Whenever I receive a message, call, whatsapp message etc. (or something that causes a notification sound or call sound), the sound freezes a bit or some cracking or lag happens just before starting to play. I tested it both with normal boot and safe boot. Is this a hardware or software problem? I need some Sony Stuff to help here. I have read all Xperia Z1 forums and some people have this problem. And it is on my Xperia Z1 Compact. This is a suberb phone and I need some help. Can I really need to go to Sony Service? or Warranty?
And is there anyone who has this problem?
131 REPLIES 131
arun7787
Hi Rickard,
When can we expect next update?
profile.country.RO.title
_alexdon_
SirRobin
Contributor
I think the main problem is the sound to earpeace bug in this fw.
Shuttering ringtones are better than nothing to hear...
Gruß Sir Robin
--> KD-55XE9305 --
walied
Since i got Xperia Z1 Compact from 2 weeks ago, Ringtone sometimes be high and other times be low randomly
Note: i update the mobile to Kitkat 4.4 after two days from buying it.
_alexdon_
They are looking into it and will be fixed in the next update.
alexdon
Andii
I heard that there will be a update at april 7th. Is it true? Does somebody know?
Aamyre
Hi guys, I have found a temp fix. Go to settings > apps > smartconnect> and then press disable. It has worked for me. cheers! PS: I love this little monster!
Andii
I deaktivated smartconnect, too. Worked for a while, but now, I have this problem again. It is not working for a long time, sorry.
Samert
updated to 14.3.A.0.757 but the crack in notification sounds is still present!
akrappa
update fixed problem for me.  no cracking in sounds, every sound and videos, games etc works like they should. thanks for quick fix!
