Hi All,
Mobile data continues to working, when I chose to stamina mode. It works although extended stanby was chose. mobile data doesn't stay off in that mode. how can I fix that problem?
Not: Apps active in stanby is empty.
My problem was solved: mobile data was closed in 15 minutes after I close keylock
Stamina mode will kick in after about 15 minutes. Does mobile data stay on even after that time? It should enable when you wake up the device.
thank you so much for help. I didn't pay attention to time. I'm going to check time up.
Keep us updated.
If it doesn't then it has been added to the exempt list
I have the same issue with my Z3 dual device. Does adding some apps that works on internet like whatsapp, line, kik, or skype to the whitelist cause the wifi or data to continue working?
if you want apps to continue working. you should add apps in exempt list. if you don't add apps in list. mobile date will be closed in about 15 minutes.
Yes, as it should. Everythings is okay
I believe your problem is solved then,in about 15 minutes data is disabled,correct?
