I often use a pin code to unlock my phone, but I also often don't. Last time I tried to disable any pin code necessary I was met with what you see in the screen shot. Anyone know how to fix this?
To enable those back,just clear credentials under settings-security.
Do you have a corpoate type email setup on your phone as this is now a standard feature of android
No, I do not. And I have made no changes in any settings from last time there was no pin and until now. =S
Does your phone have branded firmware installed or do you have any apps that would cause this extra layer of security
Have you enabled Encryption
Hi
Thanks for the same, but it again becomes greyed after some time and I have to do the same process again. ANy other permanent solution?
