@Didrik wrote:Hi @r3z4x,
How long would you say it takes before the slider dissapears? Are you experiencing the same thing if you reboot your phone to safe mode?
@ hi @Didrik
it takes 20 sec to be dissapeared from the screen. for disappear it immediately i have to touch somewhere in screen.
in safe mode, it works normally, and takes 3sec to be disappeard.
so what is the problem?
If there is that much of a difference while in safe mode I'd say it's safe to say that one of your downloaded apps is the culprit here. Unfortunately it's hard to say exactly which one it is.
I recommend that you start by updating all of your apps. If that doesn't help then you may unfortunately have to uninstall them one-by-one. I know this might take a while to do, a tip is to start with the ones most recently installed.
Glad to hear it
