Problems with NT3 smarttags
pallson
I bought nt3 smarttags for my xperia z and I have a problem because after connecting via NFC in smart connect application I can't find on the list GPS mode function which I want that will be switched on for example for Navigation - car purposes. Is it typically for this smarttags, smart connect application? The same situation is with NT2 smarttags.
Tags (1)
1 ACCEPTED SOLUTION
10 REPLIES 10
Thommo
It maybe called Location now with new firmware so check for that
pallson
So what exactly should I do?
Thommo
You said you couldn't find GPS but it's now called Location
pallson
I have no "location" on the list "add start action"in my Smart Connect application.
Uliwooly
you should leave GPS on at all time, that's my opinion.
pallson
Thats not an answer to my question. GPS is eating a lot of the baterry power
pallson
I seen videos on YT with Nt1 smartags and the GPS option was available
Uliwooly
I'll try to find the reply, but I believe Rickard replied to this and said that its no longer an option even with the NT1.
