smart call handling (shake to reject/Turn face down to silent the mobile) & Arabic language
Moodyz
Hey All
I got my z5 permimum dual since 10 days now & i got the new update
What i have noticed up till now :
1- sometimes when i need to unlock the mobile i find the fingerprint sign at the bottom of the screen & sometimes not,why?
2- Power management tool has disappeared after the update?
3-smart call handling (shake to reject/Turn face down to silent the mobile) isn't working at all,why?
4-missing Arabic  letter in Keybaord?
waiting for your comments.
3 REPLIES 3
RobertoDS
Contributor
1 And where other times ?
2 Do you mean about "STAMINA" ?
3 Are your proximity sensor and luminosity working well ?
4 I can't help you for this, but have u checked in Language under KEYBOARD ?
AymanB
Also you can not reject or decline incoming call with SMS.
Moodyz
hi robertods
1- I mean somtimes i find the fingerprint sign to unlock, other times i only find the lock sign which is alittle bit strange ,so how to show only fringerprint sign?
2-yeah
3- i check Proximity sensor i found it off
4-no worries problem sovled
