Sony Explore Not working
ROZWIĄZANE
scorpio92
Początkujący
Hi. I got my Z1 back a couple of days ago from repairs on the screen. Everything works besides my Sony Explore app. It looks like it keeps refreshing and when I try to click on a subject it jumps back to the Explore screen and the load bar keeps flashing... I don't see an update on the app either...
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
scorpio92
Początkujący
O and found the link to Sony Explore south Africa as wellhttp://www.sony-africa.com/microsite/south-africa/index.html?m=0 thank you for the support guys
Wyświetl rozwiązanie w oryginalnym poście
11 ODPOW. 11
Uliwooly
Are you referring to the browser? if you are that's no longer supported, as its all about Chrome now
scorpio92
Początkujący
Don't know if it part of the browser... When I open the app it shows me product information, nearby stores, new Sony products etc... If it's not supported anymore, then why did Sony Keep the app after they wiped the phone, hard drive etc. And uploade the newest software...
Uliwooly
Which android version do you have? bc the browser its long gone
Thommo
profile.country.RO.title
_alexdon_
scorpio92
Początkujący
Definitely was not the browser, lol... Thanks Thommo, it was the app afterall. NOW it shows me page can not be displayed... I'm uninstalling and re-installing it... The app is called Explore by Sony on Play store... Thanks guys
Uliwooly
@Thommo thanks for the heads up
scorpio92
Początkujący
Ok, found out why it's not working... South Africa does not support the app any longer... The link you gave me Thommo was the Asian Explore by Sony... It did update but would not connect... Thanks for the help anyways everyone... The "new" Sout African app is called Sony Insider.
scorpio92
Początkujący
