As title said,
my Xperia Z1 couldn't be turn on, and when i try to charge, it gives 3 vibration node, then connected to pc, then it auto disconnect again, vibrate 3 times again... And continues....
No display shown on screen when plugged in to AC plug or PC via USB... It keep vibrate non-stop when i connected to AC plug or USB...
Now i can't backup my phone using the PC companion...
Anyone encounter this? Any solution to this problem? Any method to force backup my data?
I put my phone into a air-tight container, filled with half a cup of rice.. Left it in there for 2 days.
Somehow it managed to fix the problem i had after soaking my phone in water. I think there is sips of water that sipped in the phone when bathing. Probably due to flaps not closed properly.
Now my phone is fully operational.
i had the same problem . I did like you
put it in rice for 2 days . Now charging it hopping to turn on again . one question did you restore all the mobile functionality ?
i put in rice 2 days but it didnt work .. what shold i do ?
i on my mobile no vibration .how to on
Half a cup of rice to absorb the water, but what was the garlic for?
