Xperia z2 heat issue
amraboelsafa
Hey guys, just ordered xperia z2 and ive read lots of comments how the device gets really hot even with a module usage, any thoughts?
Tags (3)
1 ACCEPTED SOLUTION
NirmalSitaldin9
Because the phone has 2 glass layers it may overheat faster, but it is normal. Considering you're a heavy user, you must be playing games, watching videos, social networks browsing etc. It can last up to a day depending if the apps are big (500mB+ games)
8 REPLIES 8
Uliwooly
It will get hot while recording on 4K or playing games, its normal.
amraboelsafa
I know but some report that their phones get extremely hot unlike other high end smartphones
amraboelsafa
Pleasd consider that im a heavy user
NirmalSitaldin9
amraboelsafa
I hope that not facing any problems
dandy63
Leader
Hi, if it gets too hot the screen displays a warning message to notify you & will then shut down to protect the phone.....have never witnessed this on mine but if you are a heavy game user you may come across this :smileysmileywink:
amraboelsafa
alright thanks guys
NirmalSitaldin9
No prob
