Xperia Z2: Stamina mode doesn't work aparently
pr0sum3r
Stamina mode doesn't work aparently on my phone. I try all the configurations but the sotware doesn't turn off the wifi and neither the mobile data coming from the operator when i block and turn off the screen of the device. I continue receiving information from all the apps and i haven't done any exception on the stamina configuration. Any idea to solve this?
1 ACCEPTED SOLUTION
rockyrocky
Hi.. Do this
Go to settings
Apps->all->eco mode controller
And clear cache and data.. Click fore stop and restart your phone.. This should work
7 REPLIES 7
rockyrocky
Hi.. Do this
Go to settings
rockyrocky
If problem still survives.. Download sony pc suite and try repairing your mobile
jaamgans
I assume that you have set the stamina mode to be active at x level of battery percentage, and the phone has actually dropped below that battery percentage level hence triggering stamina mode?
AlanDS
Looks like you are talking about Low-Battery mode...
First make sure that you have turned it ON. After that just see "Activation" section under Low Battery mode to find at what level it has been set to activate.. By default, Low battery mode gets activated at 20% battery level.
pr0sum3r
It works!!! Thanks a lot for your advice Slightly_smiling_Face
Loc
Hi. May I know how did you do to make Xperia Z2 Stamina work? I didn't find "eco mode controller" setting. Thanks!
gionni
Dont find eco mode controller!! Any help? Stamina mode doesn't work. Keep on receiving notifications. WiFi and mobile data dont turn off.
