Xperia Z5 have no notes app and also home screen rotation is not working even after changing setting in display
The auto rotation has been answered here:
/t5/Xperia-Home/Xperia-Home-Auto-Rotate/td-p/1054730
It is most probably because the device doesn't have a magnetic port so no need for a dock either.
I will lock the thread.
Notes has been replaced with google keep as far as I know. And about the home rotation, can you confirm you have tried to tap longer on the screen and edit home settings?
tapping longer on the screen giving option in home screen is only for the text small,large. i have changed setting going in to setting, display and the option "When device is rotated" and then there are two option "Rotate the contents of the screen" and "Stay in portait view".
