Hello,
I bought one Z1 Compact for my wife in December 2014
It's a great phone except one little annoying sound issue which seems i cannot solve it
I noticed from the begginig that from time to time i hear a strange swish sound like when you try to find a radio station and there is no signal at all
This happenes when audio is not used. Most frequest is when using Facebook app during scroll amond videos (videos are not played !!!!)
I tried system repair but nothing changed
Phone has last firmware update 14.4.A.0.157
Has anyone have the same issue? Is it a firmware bug or hardware? Should i send to service center?
Regards,
Razvan
Hi
Today i received the device back
Guess what! It's a new one
I checked the sound for this one. Seems to not have the same issue
Thank you Sony
In that case I would advice you to send your phone in to an authorized service center for further investigation. For more information contact your local support.
http://support.sonymobile.com/global-en/contactUs/
BR
Patrik
Hello,
Today i let my Z1c to service center
Lady from reception noticed also the strange sound
I will come back with details when i will receive a feedback
Regards
Hi
I have received a status from service center that SWAP replaced (whatever that means)
If the phone was opened i wonder if it will stiil be waterproof ...hmmmm
