New user noting that no smart lock features appear to be working on Z2 with 5.1.1
Smart lock works better although somewhat irregularly,when several trusted locations are used,all measured within my home but resulting in slightly different adresses. Although the GPS signal may be very weak and varying inside the house this was unexpected since my router IP-adress is constant over long times. Why face recognition did not work is, and remains, an open question.
Thanks for the various suggestions to help out. I have learned a lot about my new phone in the process
@tstrom Does the front cam work fine? You could learn the face more than once, perhaps it will help (it takes a while to detect the face so you need to keep looking at the lockscreen until bottom icon shows it is unlocked).
Great news.
