When I receive calls then microphone is not working for first 2 seconds and people can't hear me.
Is this some kind software problem or I should swap this phone for new one?
I mean it's sad but some times funny how my calls start like Skype calls where first thing you say is "Can You hear me?"
This problem have not occurred while calling out only while receiving calls.
The "noise suppression" issue has gone after upgrade to 5.0 but now it seems it doesn't affect anything
Hi, just wondering how you got on with your Sony Z3?
I am really getting fed up with microphone problem.
Sony store replaced 1st phone with this problem but then the second ph has been sent for repair twice and still has same prob.
No one can hear me. It's really frutsrating for both parties.
Call centres hang up on me as they say they cannot hear (which is even more frutstrating after being on hold...)
Grrrrr......
Guys I had the same problem, solved it today
Mine was running latest android 5.0.2(23.1.A.1.28) Z3 compact.
In my Music application(Walkman app updated to Music)-settings-Audio Settings- Mic sensitivity set to High.
Other person can hear me crystal clear:smileyhappy:
Your a star. Problem solved.
Thanks a lot, disabling "Ok Google" function solved the pb.
Hi do you still have the same problem.
I am totally fed up.
I can make calls only with headphone or with loudspeaker on. I could not record any voice without my headphone.
