Bluetooth connectivity
andrewjferry
Hi, I have recently purchased the sony 32wd756bu thinking that it was an all singing and all dancing tv.. unfortunately not!! Instead it's classed as a smart tv.
Is there anyway I can connect my bluetooth headphones to this tv, if so how?
Many thanks
Andrew
5 REPLIES 5
Hi Andrew,
Unfortunately that's not possible with this TV.
So you would need a BT transmitter that is connected to the headphones connector of the TV.
andrewjferry
many thanks Peter, do you mean a bluetooth dongle?
Joe_Dohn
Specialist
Yes, but you should definitely make sure it works before making a purchase (checking specs vs your headphones or checking reviews for example).
andrewjferry
thanks Joe, usually they want you to download an app first..  which of course is not possible
Joe_Dohn
Specialist
That's very true.
If you care about the audio quality, I'd recommend looking at known brands (Creative comes to mind, mainly because I remember seeing one of their dongles on this forum, randomly enough).
Hope this helps!
- JD
