1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
From:community@eu.sony.com To: socialmedia.en@eu.sony.com Cc: Sent: 24/11/2015 17:49:20 Subject: Re: [ABUSE] By: frankie1g / Board: Televisions (36298) (Sony Subscription Update) Hi EUSupport_EN,EUSupport_EN (Explorer) posted a new comment in EN Escalations on 24-11-2015 17:38:Re: [ABUSE] By: frankie1g / Board: Televisions (36298)
So when you comment and escalate a problem it's. Classed as abuse!!! Sent from my Samsung device
To turn on HDR on my KDX558509c Model, you press the "ACTION" Button on remote, scroll down to "PICTURE", Click on the Picture mode setting ( First on Menu ) and scroll all the way through the different modes like GAME/CINEMA etc and HDR should be right at the bottom.
I have only used the HDR mode on my PC, so I have no idea if the option is there for normal TV etc.
Has anyone else found that Amazon 4k (ultra HD) looks the same as standard HD? Netflix 4k looks amazing but Amazon just seems normal.
Yes it is available at all times, If you select it while watching normal TV you will noticed a dramatic increase in colours etc so basically looks awful unless you are using it for the correct content where it looks thenominal, As mentioned earlier the picture quality especially gaming is brilliant just shame that when you want to utilise it with content like netflix its hit or miss if it works..
I thought to experience the best in HDR (yet to be standardised) you need local dimming control and full array led panels, neither of which the x85 have
Technically you are correct , you do need a FALD set for proper HDR, but personally, I wasn't prepared to shell out an extra £800 - 1,000.
Just spoke with them on the phone
She read the case file then mentioned how I'd already tried updating it. I told her I've tried it through the TV, through a USB, through copying the file onto the USB twice and renaming it and that since doing all that, a new version of the firmware update has been released so I've tried it all again. She said they'd need to escalate the issue. I told her that's what I was told at the end of an hour-long phone call a month ago. She said the escalators replied with 'has he renamed the file?' - I was told to do that on the phone, *before the issue was escalated in the first place*!!! This is unbearable. I just want my £1000 telly to work
so will that report you for abuse when they escalate
