1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
Yeah I'm the same, I like the TV too much just to take it back. Does your picture actually freeze whilst it's on TV or another input? My menu system only ever freezes, so I might not be able to change channel or view the guide but the TV is still OK and I can carry on watching the programme (which isn't great if it's stuck on something rubbish!)
Do you know if using these televisions via a Virgin TiVo box or Sky Box eliminates a lot of the problems experienced with the remote , EPG , etc
No I don't sorry, I only use the inbuilt freeview HD. If someone else knows then that'll be good to know, although it'll be a lot of extra money to get those services becaues of a slow TV.
@marcuz_89 wrote:Hi, I'm developing an app in AndroidTV for SonyTV Bravia. This app is a porting from a webApp, so I use a WebView.
I have an issue, I have to differentiate and map the color keys (yellow, red, green, blue) on the remote control in JavaScript inside the webapp, but the keycodes returned by the KeyboardEvent in javascript are all equals to the code "0".
I can differentiate these buttons only in java Native Android code, what is the best way to mapping the codes in the webApp?
I've not studied the loads of Android TV documentation at developer.android.com but have a look at http://developer.android.com/reference/android/view/KeyEvent.html and constants such as:
"public static final int KEYCODE_PROG_BLUE Added in API level 11
Key code constant: Blue "programmable" key. On TV remotes, acts as a contextual/programmable key.
royabrown ha scritto:
@rooobb wrote:
What about looking at your new LG in a dark room? Its IPS panel gives you the same blacks as the Sony?
Do you mean regular blacks, or the ones the Sony does from time to time that flash onto the entire screen without warning?
i am sure the LG won't be putting up as many blacks as the Sony Android sets do 🙂
I've to admit you made a funny comment
Anyway I didn't have any black freeze on my KDL43W805C in more than 6 months, so it could be something related to UK special features I guess.... But the blacks on a living picture ... WOW... I have an IPS KDL42W805A too so I know which is the difference...
