- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
							2015 Bravia Android TV Issues
1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Julian Black is right though, we should not be looking for workarounds or anyway to fix these pieces of... well I think its obvious that these sets are not fit for use so Sony should sort it out or at least give the option to trade it in free of charge for the new 2016 model when they come out as a matter of goodwill.
Its such a shame that this has happened to a once "Premium" company but the customer in this case is just being used a a beta tester and thats just plain wrong!
NOT A HAPPY CUSTOMER!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Does anyone know if the 2016 models are better able to cope with the Android OS? They haven't been out long have they? I got my TV fom John Lewis with a 5 year guarentee so I'll be requesting a switch if the newer models are better.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have a similar set
KDL50W809CBU
I have not got that many problems. May be because i do not use the EPG in the TV. Also i have not loaded any apps other than Kodi.
Slugglishness is a general issue if you are trying to change the channels on the Tv. Best to use external box. I do have some of the issues mentioned in the forum but not that bad. Also it is best not to use the remove too fast. HDD is not working yet.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have a similar set KDL50W805CBU
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes that's another issue, the delayed update for twin tuner, picture in picture (doesn't really bother me) and HDD record which does!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I think what marks out a Premium company isn't just the quality of their products but also how they deal with any issues. Its this aspect that Sony has failed to address in a satisfactorily way. Releasing feature updates before addressing bugs, changing the feature set, not keeping the customers informed for long periods and generally giving the impression (well to me anyway) they don't have much of a clue about how to sort all this out is what marks them as not being worthy of the 'Premium' reputation they once had.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
If you do not want YOUVIEW you can use the Ireland and EU firmware version just reset your set to country of Ireland and you will receive those firmwares as they do not have the same problems as listed here with youview and the rest....
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I for one have very few issues with my android TV and put a lot of the problems down to the fact that these sets need to be COMPLETELY powered down when not in use e.g. switched off at the socket.
I power on every day and all works well if a little slow to change channels.
Future updates should bring all the goodies promised and as I have not seen a better TV for the same cash I will await these before complaining about it.
P.S. No relation to Sony!!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have the UK firmware but I've disabled YouView. I've done a factory reset but it didn't help much. I've since disabled a lot of stuff on the home screen too. Hopefully it'll make it a bit faster, I'll uninstall all the apps I know I'll never use.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
One thing I noticed is that it reports my screen resolution as 1920x1080 (it's a 49X8305C) and not 2160?
