Oreo update done on KD-65XE9005 and since this update the tv keeps stating ‘Ethernet is not connected’ and I can not use tv as for you tube Netflix etc.
I have tried a soft soft reset and it doesn’t work.
can anybody assist? Thanks
Have you tried simply to disconnect and reconnect the Ethernet cable?
Manolo
Evening,
yes tried that numerous times works for 20minutes then get a repeat of the message and won’t work.
Sorry if I ask but, of course, also Router side? And ... have you tried a reboot of the router?
Manolo
No worries
yes tried connecting reconnecting Ethernet both sides and router reset about 2hours ago
Have you tried turning off IPv6 on your router ? Seems to solve a lot of connection issues . Did for me anyway .
