Sony 55xd7005 wifi connection
profile.country.HU.title
Istvan958
Hello,
I have Bravia 55XD7005 , just updated to Oreo.
Cannot connect to WiFi network wen wired Lan is connected.
I see the WiFi networks but when want to connect it say: "cannot find the xxxx...network" If disconnecting Lan cable it connecting imidiately.
Is it a normal behavior or something is wrong with the new firmware?
1 REPLY 1
rooobb
I do not know which error may rise, but why on earth you want to connect to WIFI when your are wired?
