Wireless connections
soulman-ian
probably been asked a thousand times before . But my sony bravia kd-43x8309c
doesn't find the router wireless .it used to . but not now .. have tried rebooting router and tv .
Help please .
11 REPLIES 11
profile.country.GR.title
MiCal1967
Contributor
Yes you can use a powerline to check. Easy solution and Very fast.
soulman-ian
right I turned the router off for a couple of hours ,so that it could reset. Came back on and the TV found it straight away and connected .  so fingers crossed that this is the solution and it will stay working after tv has been turned off and turned back on .
