X8509 picture issue?
mifiddl
HI,
I have a 55X8509 set that I picked up last September time from Sony.   I've spent some time adjusting picture settings but I have one big problem.   When there is an image with high contrast, I get a 'halo' effect of 'smears' fading out from the bright to the dark.  The picture is taken from a Blu Ray, but I get the same issue on any source.
Any thoughts on a setting I can tweak?  Does anyone else get this?
cheers!
mike
2 REPLIES 2
Not applicable
Hi there
I have an X8577 TV and do not get this.  However the first couple of things to do is:
  • Ensure that you have the latest firmware installed - you should be on 3.865
  • Factory reset the TV - instructions HERE
You will need to re-setup the TV again after a factory reset, but give that ago - as its sometimes amazing that it works on many weird and wonderful issues.
mifiddl
HI Thanks...I have the latest software (and updated again last night!!)
I will spend some time at the weekend experimenting with settings, and trying a reset  🙂
If others have this set and do not get this, I guess that means I am edging toward having a faulty set?  Can I contact Sony themselves via these forums if thats the case?
Cheers everyone!
m
