C4 - Issue With Proximity Sensor
c4User
Got my xperia c4(E5363) this afternoon and noticed an issue with the proximity sensor. When I make a call and bring the phone near my ear, the screen becomes black BUT it does not recover even when I take the phone away from my ear. It remains black only. Even pressing the power button does not help.
The only workaround is that I have to remove the sim, which causes the phone to reboot. Once its up, I need to shut it down again, re-insert the sim and restart. Slightly_frowning_Face
pls help !!!
1 ACCEPTED SOLUTION
profile.country.RO.title
_alexdon_
It could be related to the screen protector,this has been noticed in the past on other devices. Now I can't force you to take it down.
alexdon
14 REPLIES 14
_alexdon_
Can you check if the same occurs in safe mode?
/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
Also,do you have a screen protector or a flip case?
alexdon
c4User
Thanks for your reply.
I tried the safe mode and still have the same problem.
I am using a screen protector
_alexdon_
alexdon
c4User
yeah, that could be an issue. Anyways, given that I got the handset only yesterday afternoon, so I'll take it to sony repair center before removing the screen protecter. cheers.
c4User
just back from service centre. you were right. it was the screen protector !!!!
It has been removed and the phone works like a charm now.
Many thanks for your help !!!!!!!  Slightly_smiling_Face
_alexdon_
Great,enjoy your device.
alexdon
Sarfaraz
Great!!! Screen Protector issue is very common nowadays. I request you to use only screen protector which are made for your device
Augur
I had the same problem with the sensor.. But it OK now when I just removed screen protector. Thanks friends
CatalinaGMM
Got my xperia c4(E5363) a few weeks ago and I noticed an issue with the proximity sensor too. When I make a call and bring the phone near my ear, the screen becomes black BUT it does not recover even when I take the phone away from my ear. It remains black only. Even pressing the power button does not help.
I don't have screen protector, I've already tryied in safe mode too, but nothing seems to work. Is there any way to deactivate the sensor?. Pls help me.
Catherine.
