notification light not blinking
ROZWIĄZANE
Ya_Kha
Początkujący
The notification light does not blink, I don't understand why, if some one can help, how to make it blink.
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
Uliwooly
I don't quite understand your question, the notification light should work, just disable the stamina mode and it should work just fine
Wyświetl rozwiązanie w oryginalnym poście
8 ODPOW. 8
Hi Ya_Kha,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Are you able to supply more information, is this only for certain apps or does this happen with all applications, does the charge LED work or is this localised to notifications only?
Sorry for this inconvenience.
Uliwooly
Do you have stamina mode on?
Ya_Kha
Początkujący
Yes stamina mode is on
Uliwooly
Turn it off and check again, the "problem" is Stamina mode
Ya_Kha
Początkujący
Still the problem remains, is there a option of notification lights, in the phone.
Uliwooly
Does the LED turn on when its connected to the wall charger?
Ya_Kha
Początkujący
Yes, but is there a option of notification light available in the phone
Uliwooly
