Settings > apps > all > smartconnect > clear data > restart your phone > check again.
Hi Wili,
Discussion Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines
Are the headphones Sony Mobile based or are they third party, also are you using Bluetooth or a direct connection?
In most cases the issue is resolved by following Uliwoolys instructions, so try this first and test and if the issue continues, supply the information requested above.
Awesome
That's great news, glad we could be of assistance
