I cannot switch on my Xperia T smartphone... This morning I charged the phone, then I switched it off... and now it is impossible to switch the phone on.... what can I do??
Try to press and hold both the on/off and volume up key until you feel one vibration.
If it still wont start, try holding the same keys until you feel three vibrations in a row. Then try to turn it on as usual.
Thank you so much !!!! After three vibes it worked!!
when I press powert button the red LED bliks. I cant also repair with update service, because installation of updates fails before it finish
I have a problem with my Sony Xperia E. I was updating it and it suddently turned off, and I can't to turn it on now. Can you help me, please??
