i had dropped my xperia p in water and after 1 hour had dried it by dryer but it dosent turn on while i plug charger to it. it blink red light for a sec and then also it dosent turn on pls tell me what should i do....
But it dosent enter in boot mode and it also does not charge through charger.the handset is fully dead pls give me some another idea...
You shouldn't use the dryer,it could have damaged it even more.Stop by a sony service:
http://www.sonymobile.com/global-en/support/contact-us/
what now i can do for turning on my device....
You could charge it for about 2 hours and try to repair wtih SUS:
http://www.sonymobile.com/gb/tools/update-service/
Why don't you take it to a sony service?
today my xperia p get on but it gets hang and charging is not going aboye 21% pls help....
Take my above advice.
