How to restart Sony xperia sp when it gets hang up
nkrrish
My phone Sony xperia SP hangs up and unable to restart the device. It is really hard to be like tat for long time. Pls anyone help me ASAP.
1 ACCEPTED SOLUTION
Vipin91
Open the back cover.
There is a slot with Off written on it.
Put a pen in that slot and press till the screen is off.
It will restart the phone
21 REPLIES 21
Henke
Contributor
Hold down on/off button and volume up until you feel a vibration (phone will restart)
Hold down on/off button and volume up until you feel 3 vibrations (phone will turn off)
Any better?
VinayAradhya
Hey buddy. When your Sony Xperia SP hangs, just remove the sim card. It will restart automatically.
thesoham
Spoiler
well you just need to take off back cover and press the off switch with a pin/pen above the led stip on the back
Spoiler
Amal1XSP
Thanks a lot buddy.. I have just started using XP 2 wks back and suddenly Touchscreen did not respond. But using your solution it is working back.
Any permanent fix for this or root cause for this?? Pls advise
Vipin91
o1
Nice review.
I have tried it when my mobile hanged up. Its working.
Thanks a lot.
Manish143
500% Work Love It AAA++++++
fedebt
I will never remove SIM card when the phone is ON.
It can be dangerous for the SIM card, i personally broke one removing with phone ON.
Push the reset button.
It's safer to do that.
prodigy
Contributor
Hello.
Do this by only pushing the reset button on the back of the phone after removing the backcover.
