- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
My internal phone memory is getting eaten up fast, how can I move the applications and make installations go directly to the SD card?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
When you say you are getting low, how low is low?
If the memory is being taken up by apps, then there isn't anything you can do currently as you can't load apps to run from your SD card. I may be wrong but I think this will change with the 2.1 update.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Try mounting your SD card first. It can be found in Settings under SD card
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
My SD card is currently mounted, and applications are taking the space up. Is there any news of when the 2.1 update will be available?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The official line is the end of Quarter 3 so probably September. I think the hold up then is going to be the tel co's putting there rubbish on the top of it before they release the updates. But fairly soon really.
Out of interest what apps do you have that are hogging all the space then? If you go to Menu>Settings>SD Card and Phone Storage... what figure do you have for internal phone storage? I have a fair few on my phone and still have quite a lot of space left 303mb. Do you use them all? If they are freebies, you could always ditch them for the time being and then reinstall if you genuinely need them.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I currently have 127MB left, I don't know what the internal memory is for the X10 Mini Pro when it's new. How much does the average app take up?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
According to SE website specs it starts with 128mb so actually you have only used 1mb if thats the case!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
After deleting a few applications, I've now got 140MB..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
 Good to see that the SE website have their facts right then. Lol.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Haha, I guess I'll just wait for the Android 2.1 update. Thanks :smileygrin:
