Power\lock button does not working
Aspong
I have just tried to unlock my phone using the power button and the phone is completely unresponsive. I have tried connecting it to the charger, pressed the reset button, everything I can think of the screen is completely black. The phone is still on as it keeps vibrating to tell me I have messages and my colleague tried to ring me and it rang and vibrated, but the screen stays off...
Please help me! I haven't done anything, it has been sitting on my desk all day, it hasn't been near water, been dropped nothing. It's only about a month old...
Thanks!
1 ACCEPTED SOLUTION
Cot88
Enthusiast
Did you try to keep pressed the power button for 10/20 seconds?
Did you try to keep pressed the off button under back cover with the tip of a pen for same time?
Try also to connect to a PC/Laptop and verifiy if is recognised and if you can access to internal memory
15 REPLIES 15
Cot88
Enthusiast
shihstouch
Enthusiast
Try Restart
Restart your phone to turn off all running applications and to free up memory. Remove the back cover. Press and hold down the OFF button using the tip of a pen or a similar object. The device turns off automatically. After the device is turned off, restart your phone.
blechie
I have a problem on my camera key. Its not working when im using it. The flash just turning on but it doesnt campture picture. Please help me.
phani12599
I tried all options but none of them work. Also my warranty expired last month and my phone automatically switched on after removing and reinserting my battery but lock/power button still not working. It makes me I kept my phone idle for long time also there is no option to disable lock in my phone only screen turnoff I can manage but it consumes more battery than previous.
DepecheMode
It Works!
Thanks!
saurabh88
 i get black illuminated screen when unlocking the phone and have to press it multiple times to again unlock it properly to get the screen on
sahood
some one please tell me the solution for this problem..i cant wake my up screen without power button..everytime i have cal from another number to make my screen on..please tell the solution
sahood
i just trowed my mobile from around 5 feet to bed..believe me it worked...i tried all the things finnlay got fed up and trowed..now its just fine.
Hawkern
I got feed up too and hit the phone hard in the desk.... guess what the button works again, crazy **bleep**e Slightly_smiling_Face
