Problem of the sound is not loud -Xperia T-
LachiriYoussef
Hello there
My problem that the sound of music or notifcations coming out of the speaker is not loud, I made an update but the problem is not resolved.
I want to know is that all the "xperia T" have the same problem or what? if not what should I do.
thank you
1 ACCEPTED SOLUTION
Uliwooly
Not at all, the Xperia T its louder than the Xperia Z, but not louder than the Xperia Arc, or Xperia S. You can stop by your local Sony Xperia Care to be certain
http://www.sonymobile.com/global-en/support/contact-us/
15 REPLIES 15
Uliwooly
This is an English only forum
LachiriYoussef
Sorry I corrected
Uliwooly
is Xloud on?
LachiriYoussef
YEs Face_with_rolling_Eyes
But nothing special
Uliwooly
are you certain that the notification sound its up or all the way up ?
LachiriYoussef
Oui je suis sur est certain, comme je vient de signaler j'ai méme fait une mise à jour mais rien, et lorsque je le compare avec mon "Xperia Arc S" je trouve une grande diférence
Uliwooly
how about the music? is it louder than the notifications?
LachiriYoussef
No, but the music for the call is not strong if I'm on the street I do not hear the audio but with earbuds (they are not original) music works well.
I install applications to increase the sound but NOTHING
Spoiler
Slightly_frowning_Face
Uliwooly
In that case, there's nothing you can do as that's a hardware limitation not software
