Hello there
My problem that the sound of music or notifcations coming out of the speaker is not loud, I made an update but the problem is not resolved.
I want to know is that all the "xperia T" have the same problem or what? if not what should I do.
thank you
Is this is a problem for smartphone Xperia T '
Not at all, the Xperia T its louder than the Xperia Z, but not louder than the Xperia Arc, or Xperia S. You can stop by your local Sony Xperia Care to be certain
Ok Thanks, I should not compare it with Xperia Arc S?
this is normal after you?
Yeah, I had multiple Xperias and the Arc its the loudest
thank you very much
Anytime
